Do Lorex Security Cameras Work With Swann 960H CCTV DVR
Home › Forums › CCTV Security Camera Support › Do Lorex Security Cameras Work With Swann 960H CCTV DVR
  • Some Lorex security cameras will work with a Swann CCTV DVR, but it depends on the video format. A customer recently contacted me with the following question.
    I have a Swann DVR model 83425H and I bought some Lorex LAB243 security cameras. So far, I am unable to get them to work. Do you know if these cameras are compatible with my Swann DVR?
    This is the information that I provided to this customer.
    Your Swann 83425H DVR is a 960H analog CCTV DVR. Swann 960H DVRs will only work with analog CCTV cameras like these.
    https://www.cctvcamerapros.com/CCTV-Security-Cameras-s/50.htm
    Those Lorex LAB243 cameras are 4mp resolution HD-over-Coax type security cameras. Unfortunately, these they are not compatible with your Swann DVR. If you want to use modern high definition BNC cameras, I suggest that you replace your old analog Swann DVR with a Viewtron hybrid DVR. Viewtron DVRs will support your all of your existing analog 960H cameras, and you can use the latest 4mp BNC cameras and even 4K BNC cameras on the same system. This allows you to upgrade your cameras over time.
    If you plan on using your old Swann DVR for a while longer, I recommend you get a 1080p resolution hybrid BNC security camera with 4-in-1 hybrid functionality, so that you can upgrade later.
    Our hybrid cameras have an analog 960H video mode that will work with your existing Swann DVR. They also have 1080p high definition modes which is extremely useful when you later upgrade your DVR to high definition.
    Infrared Turret Dome Camera
    You can switch the cameras in one of the HD video modes. The video mode is very easy to switch using the small joystick that is attached to the camera’s video cable.
    I highly recommend our Viewtron surveillance DVRs when you are ready to upgrade. They work with 960H, 2 megapixel, 4 megapixel, 5 megapixel, and 4K resolution cameras.
    Viewtron DVR
