How-to Connect Defender HD Security Cameras to HDMI TV Input
Home › Forums › HD-over-Coax Security Cameras › AHD CCTV Cameras / Analog High Definition Security Cameras › How-to Connect Defender HD Security Cameras to HDMI TV Input
  • This is how you can connect Defender HD security camera to an HDMI input of a TV or capture card.
    The latest defender HD security cameras use AHD video format (analog high definition). If you want to connect a Defender camera to a TV or video capture card via HDMI, you can use this AHD to HDMI converter.
    https://www.cctvcamerapros.com/AHD-to-HDMI-video-converter-p/ahd-cv7.htm
    You can also use the BNC output of the AHD-CV7 converter to send the video signal to a Defender DVR or any other AHD compatible DVR.
    HD Security Camera to HDMI TV
    The above diagram shows how this is done using an iDVR-PRO DVR from CCTV Camera Pros. The same installation can be applied to Defender DVRs and HD security cameras.
    I recently had a customer that wanted to connect his Defender camera to an HDMI capture card that installed in a PC. This AHD-CV7 works for this application as well.
