Is my QSEE NVR ONVIF Compatible?
Home › Forums › IP Camera Support › Is my QSEE NVR ONVIF Compatible?
  • Many customers are looking for replacement IP cameras for their QSEE IP camera systems. QSEE went out of business earlier this year, so QSEE IP cameras are no longer an option.
    These customers basically need to know if your existing QSEE NVR is ONVIF compliant. ONVIF is a video and protocol standard used by security camera manufacturers that promotes standardized interfaces for effective interoperability of IP-based physical security products. If your NVR supports ONVIF, then you can use a Viewtron IP camera with it. You can find all of our ONVIF compliant cameras here.
    ONVIF IP Cameras
    Unfortunately, QSEE did not make it obvious in their product specifications which NVRs are ONVIF compatible. You can check on some QSEE NVRs accessing the NVR setup screen and choosing to manually add an IP camera to the system. Sometimes there is a drop-down box to select the protocol of the IP camera you are adding. Check to see if ONVIF is an option. Please note that this dropdown is not present on all QSEE NVRs.
    Please visit this page if you are looking for a QSEE NVR replacement.
    If you need further help, please contact me at mike@cctvcamerapros.net.
