Swann Compatible 180 Degree Camera
Home › Forums › HD-over-Coax Security Cameras › Swann Compatible 180 Degree Camera
  • Here are two great 180 degree security cameras that are compatible with most Swann DVRs.
    A customer recently contacted me with the following question.
    I have a Swann DVR-4600 model surveillance DVR. One of the cameras that was included with the DVR system has gone bad. I wanted to replace it anyways with a camera with extra wide angle of view. I was wondering if there are any 180 cameras that are compatible with Swann DVRs.
    This is the recommendation that I gave to the customer.
    The two 180 degree security cameras (BNC output type) that CCTV Camera Pros supplies are both compatible with the Swann DVR-4600 as well as many other Swann models. They are both on our best sellers list.
    180 Dome Security Camera
    The HD-D180 is a 180 dome camera. It can be ceiling or wall mounted, indoors or outdoors. It has built-in infrared night vision.
    180 Degree Wide Angle Security Camera
    The AHD-BL25 180 degree bullet security camera basically is the bullet-style version of the HD-D180. It uses the same 180 degree lens and HD image sensor. Like the dome version, it supports 1080p / 2 megapixel resolution.
    Both of these cameras will work with your Swann DVR. By the way, CCTV Camera Pros is currently running a promotion that gives customers a 15% discount plus free shipping on all HD security cameras and hybrid surveillance DVRs.
    Please use coupon code “15hybrid” at checkout.
    Swann Replacement DVRs
    Please check out this article if you are looking for a Swann DVR replacement.
