Export License Plate from Viewtron NVR
Home › Forums › Viewtron Security Camera Systems Support › License Plate Recognition (LPR) › Export License Plate from Viewtron NVR
  • To export a list of license plates from Viewtron IP camera NVRs, please follow these instructions.
    1. Insert a USB thumb drive into the NVR (front or back USB on the NVR will work fine)
    2. Navigate to START > INTELLIGENT ANALYTICS > Select VEHICLE > Now set the DATE , CAMERA and make sure EVENT is set to PLATE DETECTION
    3. Now you should see a list of all the plates captured, simply check the plates that you wish to export > Check BACKUP PICTURE > Click the BACKUP button
    This will export a .CSV with the plate info , time , date etc + a snapshot of the plate. I have attached an example of what is exported per plate selected.
    NVR license plate export
