Hikvision NVR Compatible Cameras
Home › Forums › Viewtron Security Camera Systems Support › IP Camera Support › Hikvision NVR Compatible Cameras
  • For customers looking for Hikvision NVR compatible cameras, please check out our Viewtron IP cameras.
    https://www.cctvcamerapros.com/viewtron-IP-cameras-s/1474.htm
    They are all ONVIF compliant and will work with any ONVIF compliant Hikvision NVR (most are).
    Also please note that Viewtron IP camera are NDAA compliant. A lot of our customers that are concerned about NDAA compliance have replaced their Hikvision NVR with a Viewtron NVR (also NDAA compliant).
    If you want to replace your Hikvision NVR and use your existing security cameras and cables, see our Hikvision NVR Replacement page.
    FCC update (as of September 30, 2026):
    • July 16, 2026: The FCC prohibited importing and marketing previously approved Hikvision and Dahua video surveillance equipment for public safety, government facilities, and other national security purposes (Federal Register, Jul 6, 2026).
    • October 13, 2026: New FCC rules take effect that block authorization of new devices containing logic-bearing components from Covered List companies such as Hikvision and Dahua, and that define “critical infrastructure.” The FCC has stated that the import and marketing prohibition for critical infrastructure surveillance also takes effect that day (Federal Register, Sep 11, 2026).
    • What did not change: You can keep using Hikvision or Dahua equipment you legally purchased. The FCC rules do not require anyone to remove installed systems.
    Replacing a Hikvision or Dahua DVR or NVR? You can use your existing security cameras and cables. See our NDAA compliant Hikvision and Dahua DVR / NVR replacement guide.
    If you are looking for a license plate recognition camera compatible with your Hikvision NVR, please check out our Viewtron LPR camera page.https://www.cctvcamerapros.com/License-Plate-Recognition-Systems-s/1518.htm
    If you need help determining which IP cameras are compatible with your Hikvision NVR, please email me at mike@cctvcamerapros.net.
