Are REOLINK IP cameras compatible with Viewtron DVRs and NVRs?
Home › Forums › Viewtron Security Camera Systems Support › Security Camera System Design and Installation › Are REOLINK IP cameras compatible with Viewtron DVRs and NVRs?
  • REOLINK IP camera models that are ONVIF compliant are compatible with Viewtron NVRs and DVRs. In order to use a REOLINK IP camera with a Viewtron recorder, you must turn on ONVIF and RTSP support in the camera’s settings.
    Access your REOLINK IP camera’s configuration screen in a web browser or on your mobile phone. You can do this by scanning by scanning the QR code for your camera on the mobile app.
    In the Reolink App go to DEVICE SETTINGS > NETWORK > ADVANCED. Then Enable the HTTP + RTSP and ONVIF (if available).
    REOLINK IP camera enable ONVIF and RTSP
    Please note that some REOLINK camera models do not have the option to manually enable ONVIF support in the camera’s settings. This may be because ONVIF is enabled by default, which means you can still use the camera with a Viewtron IP camera NVR or hybrid CCTV DVR.
    You can find all of our ONVIF compliant IP cameras on this page.
    If you have additional questions about setting up your REOLINK IP camera with a Viewtron NVR, you can always email us at info@cctvcamerapros.net.
