Running Security Camera Cable Near High Voltage Power Lines
Home › Forums › Viewtron Security Camera Systems Support › Security Camera System Design and Installation › Running Security Camera Cable Near High Voltage Power Lines
  • Customers ask us about this a lot: can you run camera cable next to a 220 volt line, and will it mess up the video?
    Yes, it can. It depends on whether the camera cable runs parallel to the power for a long stretch, or just crosses it. How noisy the power circuit is matters more than the voltage number on the breaker: a long run next to a heavy 220V feeder or a motor load is the problem case. Ordinary indoor 110V lighting and receptacle circuits are usually much quieter.
    Parallel vs crossing
    When camera cable (Cat5e or Cat6 for IP cameras, or RG59 for BNC / HD-over-coax cameras) runs alongside a high-current power line for tens of feet, the power line puts out an electromagnetic field the whole way. The camera cable can pick that up. On IP / PoE cameras you may see dropped packets, pixelation, or freezing. On analog or HD-over-coax cameras you may see rolling lines, hum bars, or tearing. Cameras that reboot are more often a PoE or power-supply issue than 60 Hz from a quiet branch circuit.
    If the camera cable just crosses the power conduit at about 90 degrees, the exposure is short. That is the right way to cross power with video or network cable, and it is usually not a problem.
    How much space
    For a long parallel run next to 220V or a motor load, keep as much separation as you can. A foot to a foot and a half is a good field target, not a code number. Separate conduits help. Grounded metal conduit and being underground add some shielding.
    If the run is next to a motor load (AC compressor, well pump, welder, large HVAC), treat it like the 220V case even if the nameplate says 110V.
    IP cameras (Cat5e / Cat6 / PoE)
    For a normal house or office run that is not parked next to 220V, quality unshielded Cat5e or Cat6 is what we use every day. We sell Cat6 patch cables and 1000 ft Cat6 UTP spools for Viewtron PoE NVRs and IP cameras.
    If you cannot get that separation from a heavy power or motor circuit, shielded Cat6 (STP) is the better cable. We do not sell STP or shielded RJ45s, so that cable comes from a third party. Terminate it with shielded RJ45s. A common CCTV practice when two ends sit on different building grounds is to bond the shield at the NVR / rack end only and leave the camera end floating (a standard plastic RJ45 at the camera is fine). Grounding both ends can create a ground loop.
    Plug the NVR into a properly grounded 3-prong outlet. Do not use a 2-prong cheater adapter. The 16-channel Viewtron NVR uses a 3-prong IEC power cord. The 8-channel NVR uses an external DC adapter; plug that adapter into a grounded outlet. Do not land a ground wire on the alarm GND terminal on the back of the recorder. That terminal is for alarm sensors, not protective earth.
    Use solid-copper RG59 with 95% braid, not cheap CATV cable. We cover why in Best Coax Cable for CCTV Camera Installations. We sell RG59 Siamese (1000 ft spool) for video plus power.
    Same routing rules: do not run it parallel to 220V for a long stretch; cross at 90 degrees. If you already have rolling bars or tearing, that is often a ground loop. A BNC ground loop isolator on that camera is the quick test.
    Distance
    Interference and voltage drop both get worse with length. See What is the Maximum Cable Length for CCTV Camera?
    Quick checklist
    1. Cross power at 90 degrees. Do not run parallel if you can avoid it.
    2. If you must run parallel to 220V or a motor load, keep about 12–18 inches of separation and use separate conduit.
    3. IP: Cat6 UTP for normal runs. If you cannot get that separation, use properly terminated shielded Cat6 (not something we stock) and bond the shield at the NVR end when the two ends do not share a ground.
    4. BNC: solid-copper RG59, same routing. Ground loop isolator if you already have rolling bars.
    5. NVR/DVR on a real grounded 3-prong outlet. Do not use the alarm GND screw as a chassis earth.
