SuperLive Plus App: Device has been bound and access is restricted
Home › Forums › Viewtron Security Camera Systems Support › Mobile App for iPhone & Android › SuperLive Plus App: Device has been bound and access is restricted
  • A customer emailed us after they got this error in the SuperLive Plus app: “The device has been bound and access is restricted”.
    SuperLive Plus Device List showing the error The device has been bound and access is restricted
    This can happen with Viewtron DVRs, Viewtron NVRs, and Viewtron IP cameras. All of them can be added directly to the SuperLive Plus app with a QR code that maps to a NAT serial number. The usual fix is to unbind the device, then add it again with the username and password, not the security code, using our Viewtron mobile app setup guide.
    What is SuperLive Plus account binding?
    SuperLive Plus account binding is generally used when a single user wants easy access to multiple Viewtron NVRs and DVRs without having to re-enter the recorder’s NAT serial numbers and passwords. If they ever replace their mobile device, they can log into their SuperLive Plus account without having to re-add the recorders.
    In most cases, we recommend staying away from account binding because it can lock other users out by requiring an Access Code.
    Why does SuperLive Plus say the device has been bound and access is restricted?
    This error likely stems from account binding. Someone may have used the Security Code to connect the recorder to their app by accident, which automatically binds the recorder.
    How do I unbind a device from SuperLive Plus?
    These unbind steps are shown on a Viewtron NVR or DVR. The same binding issue also applies to Viewtron IP cameras that are added directly to the SuperLive Plus app.
    1. On the NVR or DVR, go to Start -> Settings -> Network -> NAT. Then click the email address next to Bound to unbind the recorder. It will ask for the recorder username and password.
      Viewtron NVR NAT settings screen with Bound next to the email address used to unbind the recorder
    2. Next, log out of the SuperLive Plus app for all users. The app should show Not logged in, as in the screenshot below.
      SuperLive Plus app menu showing Not logged in after signing out of the account
    3. Delete the recorder from the Device List if it still appears. The screenshot below shows the trash icon on the Server List in SuperLive Plus.
      SuperLive Plus Server List with the trash icon highlighted to delete a recorder
    4. You can now re-add all users by following the Viewtron mobile app setup guide. Add the recorder using the Username and Password, not the security code.
    If SuperLive Plus shows the recorder as offline instead of bound, see SuperLive Plus Mobile App OFFLINE outside of USA.
    Need help? Email info@cctvcamerapros.net.
