How to setup CCTV cameras for Live Website Video Streaming
Home > CCTV Security Camera & Video Surveillance System Forums > CCTV Security Camera Support > How to setup CCTV cameras for Live Website Video Streaming
This topic contains 0 replies, has 0 voices, and was last updated by  Mike Haldas 4 years, 3 months ago.
  • #31588
    A customer recently contacted CCTV Camera Pros and had the following questions related to how to setup CCTV cameras for live website video streaming.
    I am looking to set up a live web feed from my beach house to my web site. I am looking to find out what I would need to do this. Below are some of the requirements I am looking at.
    1. Outdoor Camera with long range lens (was thinking a box camera with 60mm)
    2. Some kind of specialized video server that can enable me to push data directly to LIvestream or Ustream
    3. Would prefer .264 or MPEG4
    I can get power and to the camera so either an analog or IP camera is fine. I also have the connection to high speed internet connection. I would prefer not to use a full PC as I will only have access to the equipment every 4 months or so. Also Power is Extremely expensive so I am looking for something efficient.
    My recommendations for this customer:
    Here are two option for you to consider. The first does require a PC and uses a service like uStream or Livestream to broadcast. This option should be used if you expect to have more that a few simultaneous users viewing the video stream at the same time.
    Please take a look at this article I wrote that explains how to use CCTV cameras for live website video streaming using services such as uStream or Livestream.
    http://videos.cctvcamerapros.com/live-cameras/cctv-cameras-ustream-video.html
    A high resolution box camera in an outdoor housing is a good choice. Here are two box cameras for you to consider:
    http://www.cctvcamerapros.com/Box-Surveillance-Camera-p/pro-680dn60.htm (6-60mm lens)
    http://www.cctvcamerapros.com/CCTV-Box-Camera-p/pro-680dn100.htm (5-100mm lens)
    Here is a weatherproof IR camera (built in night vision) that is also worth considering:
    http://www.cctvcamerapros.com/Night-Vision-CCTV-Camera-p/bipro-s700vf50.htm
    The second option works very well for websites that do not expect to have a lot of users viewing the video at the same time. This option uses an IP camera and does not require a PC.
    The setup can be found in this article "How to Embed IP camera live video in a webpage".
    -Mike Haldas
