Setup Multiple Live Security Camera Displays on Dedicated TVs
Home › Forums › Viewtron Security Camera Systems Support › HDMI / IP Encoder Decoder › Setup Multiple Live Security Camera Displays on Dedicated TVs
  • A customer with an 8-camera NVR wanted to display three of his security cameras, each on a dedicated TV. He sent us the following question.
    “I want a live video display of each IP camera from my security system on its own dedicated TV. For example, the backyard camera on one TV, the front door camera on another, and the garage camera on another. I assumed that I would be limited to the main HDMI output of my NVR, and that I could only duplicate the one camera layout with an HDMI splitter to share with all TVs. Is there another way to display a 3 different single camera views on three separate TV monitors?”
    Yes, it is possible. You can connect the HDMI output of a Viewtron IP camera to TV decoder to each TV, and have each decoder pull each IP camera’s RTSP stream for a full screen single camera display.
    multiple IP cameras dedicated TV display
    This is how it works.
    1. The Viewtron IP cameras are connected to the PoE ports on the back of the Viewtron NVR using CAT5 or CAT6 network cable. All of the video recording, motion detection, AI events, etc. are configured on the NVR as they normally are.
    2. The Viewtron NVR is connected to a network switch or router using CAT5 or CAT6 network cable.
    3. Three Viewtron IP-HDMI-D4 decoders are connected to the same local area network as the NVR. This can be done by connecting them to the same network switch or router via network cable (CAT5 or CAT6).
    4. Each decoder is configured with the RTSP stream of one camera channel on the NVR. The decoders connect to the camera video streams over the local network via the NVR (instead of directly to the IP cameras).
    5. The HDMI output of each decoder box is connected to an HDMI input on its own TV using a standard HDMI cable. The TVs do not need a network connection.
    When the user wants to see a camera live on any of the TVs, they can simply select the HDMI input on that TV that is connected to the decoder box. Add one decoder for each additional TV.
    This same setup also works with BNC security cameras connected to a Viewtron hybrid DVR. Viewtron hybrid DVRs provide a dedicated RTSP stream for each camera channel, just like Viewtron NVRs, so each decoder can display any BNC camera full screen on its own TV. You can find the
    RTSP stream setup for Viewtron DVRs / NVRs here.
    Jump to a section:
    1. How do I show one camera per TV with a Viewtron NVR or DVR?
    2. Does this work with third-party IP cameras?
    3. What if I have a Lorex, Swann, or other third-party NVR?
    A Viewtron NVR and a Viewtron DVR both output an individual RTSP stream for every camera channel. That is a real advantage of Viewtron recorders: your IP cameras can stay on the NVR’s PoE ports, or your BNC cameras can stay on the DVR’s coax inputs, and every channel is still available to decoders on your local network. Each IP-HDMI-D4 decoder has one HDMI output and can display 1 to 4 camera streams. For one camera per TV, use one decoder at each TV and enter that channel’s RTSP stream URL.
    Enable RTSP Streams in your DVR / NVR
    DVR NVR Enable RTSP Video Streaming
    Enable RTSP on the Viewtron NVR or DVR under Settings > Network > Port. The URL format is rtsp://192.168.0.147:554/chID=1&streamType=sub, replacing the recorder IP and channel number. Use main or sub, and use sub when the camera is higher than 2mp / 1080p. You can find the full setup instructions is in this security camera to TV live view post. For eight live security camera views on eight dedicated TVs, you need eight Viewtron IP to HDMI decoders.
    Can a Viewtron IP Camera Display on TV without a Recorder?
    Yes. All Viewtron IP cameras allow you to enable an RTSP stream URL on your network.
    IP camera RTSP URL
    To enable the RTSP stream URL on any Viewtron IP camera, log into the camera in a web browser. Then navigate to the Network > Advanced > RTSP screen. Check the Enable checkbox, then click apply. You can see the primary and secondary RTSP stream URLs below the Port field on that screen. You can find the full Viewtron IP camera to TV decoder setup instructions here.
    Yes. The decoder works with any IP camera that provides an RTSP stream URL, including Lorex, Night Owl, Samsung and other IP camera brands. As long as the Viewtron decoder can reach the camera’s RTSP stream on the network, it will work. The RTSP setup for third party IP cameras will be similar to the Viewtron IP camera setup. Most IP cameras have a screen where you enable the RTSP stream URL. Other IP camera brands use their own RTSP URL path. See this IP camera to TV decoder setup topic and this Lorex IP camera to TV decoder topic.
    What about Lorex, Swann, Night Owl or other NVRs?
    If a third-party NVR, such as a Lorex, Swann, or Night Owl NVR, does not output an individual RTSP stream for each IP camera that is connected to it in the same way Viewtron DVRs and NVRs do, the decoder has to pull the RTSP stream directly from the IP camera. The decoder will not be able to reach a camera’s RTSP stream if that camera is plugged into the NVR’s PoE ports. They must be connected to an external switch instead.
    IP cameras connected to a PoE switch and connected to NVR PoE ports
    Please refer to the above diagram. The two dome IP cameras are connected to the PoE ports on the NVR. The two bullet IP cameras are connected to an external PoE switch. The PoE switch and NVR are connected to a network router, so they are on the same network. This allows the NVR to connect to the cameras on the external switch. The NVR’s PoE ports are on their own isolated network, not on the local network of the router.
    In this case of Viewtron NVRs, the NVR broadcasts the IP cameras RTSP stream via the local network, so all 4 IP camera’s RTSP stream is availble in the above diagram. However, not all other IP camera NVR brands do this. In order to use the Viewtron RTSP to TV decoder for NVRs that do not expose the RTSP URLs, you must connect the IP cameras to a external PoE switch on the local network, so the decoders can reach their RTSP URLs. The NVR can still connect to and record video from those cameras over the local network.
    Have Questions / Need Help?
    Do you have questions about displaying security cameras live on a TV with a Viewtron NVR, Viewtron DVR, or a third-party system? Email the exact recorder and security camera make and model to info@cctvcamerapros.net or call 1-561-433-8488.
